What kind of tips and tricks are people using for the Stinger at the drag strip?
Recommendations for tire pressures for RWD vs AWD? I'm guessing for RWD you'd you max out the front tire pressure and drop a little off the rear tires?
Does anyone remove the plastic engine cover and leave the hood open to help the engine cool off faster b/w runs?
Use bags of ice on the intake manifold to help cool off the engine b/w runs?
Push your car through the staging lanes to keep engine temps down?
Do you get better 60 ft times driving around the water box and just giving the tires a quick spin to clean off the the rocks/dust from the parking lot or do you go for a burnout? (Assuming you have stock or similar OEM tires and not drag radials/slicks)
Try to make it the drag strip with a 1/4 tank of gas or less to save weight?
Fold in their side mirrors to reduce drag?
Appreciate any advice you can share from your experiences with Stinger at the drag strip.
