How do lowering springs interact with adaptive suspension?
Bangor
ME
2019 Stinger GT1
Mechanically speaking how does the adaptive suspension work and how do using lowering springs impact the function of it.
Welcome, Installing lowering springs does not impact the function of the adaptive suspension. The way it work is when you put your car in sport mode it boost's the preload & rebound, so it makes the suspension a little harder. When you install lowering springs it moves the center of gravity closer to the ground in which makes for a better handling car.
pleasant garden
2020 g70 awd 3.3 sport.
I have adaptive suspension.
Putting a lowering spring on a car is going to compress the shock absorber more, and that does change the behavior of it. It is the reason why Bilstein makes different shocks B6 versus B8. Same exact shock absorber internally but has a shorter body for a lowering spring.
Your adaptive suspension will still work, but compressing a shock absorber more can shorten the life of it especially if it's more than an inch drop.
Your car your money your choice.
Sent from my LG-LS997 using Tapatalk
