Zero to 60 mph in 4.9 seconds, 1.02 g of lateral grip, and the ability to stop from 70 mph in a Porsche-like 142 feet—in a tweaked, front-wheel-drive commuter car with 61.8 percent of its 3111 pounds resting on the front wheels... although the most I've seen anyone pull 0 - 60 from this car is 5.2 seconds with exceptional skill... don't know how C&D gets these low numbers... must be shifting without using the clutch which is a talent in itself
Float shifting you can do if your engine RPM, the speed of the vehicle, and the gear you are shifting to/from is just right. The reason you can do this is because you have synchros in the transmission which allows the two gears to match rotational speeds as they come in contact
to put lightly.... took me years to get this right on some of my previous cars... gotta be pretty much exact on the rpms or you'll grind... not easy for noobs
