Kia Stinger Eibach Anti-Roll Kitshttps://www.k8stingerstore.com/products/eibach-anti-roll-kits
The Eibach Front/Rear Sway Bars affects the handling on the lower end of your Kia Stinger suspension
These tie the lower suspension components together across the rear, & helps prevent oversteer & understeer
Thicker construction over stock sway bars keeps your Stinger flatter in turns when cornering by decreasing body roll
The Eibach Front/Rear Sway Bars provide better cornering, especially at high speeds
Both Front & Rear Sway bars are a tubular solid construction and have a two-way adjustment
Specifications:
Rear Sway Bar Thickness: 19mm
Front Sway Bar Thickness: 25mm
Includes bushings for installation
Easy to install and are a direct replacement for OEM sway bars
1 Million-Mile warranty by Eibach
2018+ Kia Stinger 3.3T
