Kia Stinger Eibach Pro-Spacer Kitshttps://www.k8stingerstore.com/products/kia-stinger-eibach-pro-spacer-kits
These Eibach Pro-Spacer kits for the all-new 2018 Kia Stinger are designed to widen your vehicle's stance, improving looks and handling. With many different sizes to choose from, these kits will also help create the wheel fitment against your fender you've been looking for!
Features:
Each kit includes (2) spacers
Made from high Strength Aircraft-Aluminum Alloy
Precision engineered hub-centric - for perfect fitment and wheel balance
Lighter weight than steel wheel spacers
Comes in 10mm, 15mm, 20mm, 25mm, 30mm sizes
*May include extended studs, see installation instructions below
1 Million-Mile warranty by Eibach
2018+ Kia Stinger (All Models)
Installation Information:
Depending on the kit you choose, some come with supplied longer studs. In this case, the factory studs need to be pressed out and replaced with the longer studs.
**When using 15mm wheel spacers there must be at least 14mm minimum cut-outs in the wheel to take up the original bolts, (when using 20mm spacers, 9mm minimum cut-out, when using 25mm spacers 4mm minimum cut-outs). If this isn't the case, shorter bolts must be used. (System 5, 6). Otherwise, the use of this spacers is not possible.
**Spacers can only be used with wheels that have cut-outs (facing the hub) to clear the stock studs. Please check as follows: Original stud length (i.e. 35mm) minus spacer-thickness (i.e. 25mm) = 10mm excess stud length. The cut-out should have a depth of 11mm.
