The Mishimoto Baffled Oil Catch Canhttps://www.k8stingerstore.com/products/mishimoto-baffled-oil-catch-can
Mishimoto is proud to announce the release of our Baffled Oil Catch Can. With over a year of research and development time, Mishimoto has created the most effective oil catch can on the market. The Mishimoto Baffled Oil Catch Can was designed to separate oil particles from the PCV air that would normally have just been routed back to your intake. Custom grooves in the catch can's inlet turbulates the air longer to ensure all the oil sinks to the bottom of the can, leaving nothing but clean air to pass through the 40 micron bronze filter to the intake.
The 100% billet, 6061 aluminum can accepts -AN fittings at the intlet, outlet, and drain area allowing over 27 possible configurations. For maximum fitment options, the top cog mounting setup allows the can to be mounted from multiple angles. To make maintenance easy, the drain plug can be removed to allow for -AN return to the oil pan. The can is also 100% washable, unlike many other cans that require you to replace your filtration system.
Mishimoto catch cans are different from most air-oil-separator (AOS) systems on a few levels. First, these catch cans are not heated. This means that all of the blow-by is able to condense in the can, including low-octane oil vapors and contaminated fuel vapors. Most AOS systems also drain the blow-by back into the oil pan, while Mishimoto catch cans trap the blow-by and keep it out of the engine permanently.
Features and Specifications:
40-micron bronze filter blocks oil from depositing in ventilation system
Special engineered inlet pattern "turbulates" air longer, allowing oil to condense
Internal baffle ensures no oil escapes during high-speed cornering
Replaceable single-unit filter is easy to maintain
Inlet and outlet accept -AN fittings for various configurations
100% billet anodized 6061 aluminum with laser etched finish
Safe to use in pressurized systems
Drain plug can be removed to allow for -AN return to oil pan
Unique upper mounting bracket cogs provide versatile mounting options
Includes push-on fittings for easy installation
The Mishimoto Baffled Oil Catch Can is available in a variety of colors
Mishimoto Lifetime Warranty
Kia Stinger (All Models)
All Other Vehicles (Universal Application)
https://youtu.be/WJfwc6tMoSc
