Sign Up! To view all forums and unlock additional cool features
I would start with the recommended pressures then go from there. As a rule of thumb, I bump them about 5-10 psi to increase sidewall stiffness and to compensate for temperature fluctuation.
i also run higher than stock pressure in my snows normally around 42 in the front and rear sometimes lower the rear a few psi but haven't noticed a difference really.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
